Ir para o conteúdo principal
Raspberry Pi 3 SD Card Replacement
ΛΛKΛRΞT
ΛΛKΛRΞT e 2 outros colaboradores
Última atualização em 4 de out de 2024
35 segundos - 5 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
In this guide I will show you how to change SD card in your Raspberry Pi 3.
O que você precisa
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: passo 1, imagem 1 %32
    • The Raspberry Pi 3 should look like this closed.
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: passo 2, imagem 1 %32
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: passo 3, imagem 1 %32
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: passo 4, imagem 1 %32
    • Remove the two sides.
  5. Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, imagem 1 %32 Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, imagem 2 %32
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
    if you follow this you may brake the sd card of the raspberry pi here is a updated guide
    step 1 flip the raspberry pi over
    step 2 remove the sd card
    step 3 put new sd card in
    step 4 flip the raspberry pi back over
    done
    Kieran jones - Responder
Conclusão
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
ΛΛKΛRΞT
Membro desde: 11/22/17
229 Reputação
Autoria de 1 guia
1Comentário do guia
On the official RPi case there’s a cutout where the SD card inserts. This is a pointless guide to be honest.
Stephen Wilson - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 33
Ao todo: 2,256
