Ir para o conteúdo principal
RYOBI P422 Body Replacement
John Lamanuzzi
John Lamanuzzi e 5 outros colaboradores
Última atualização em May 7, 2024
15 minutos
Moderada
Melhor Introdução
O que você precisa
Ferramentas
  1. RYOBI P422 Body Replacement, Battery and Handle: passo 1, imagem 1 %32 RYOBI P422 Body Replacement, Battery and Handle: passo 1, imagem 2 %32
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: passo 2, imagem 1 %32
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: passo 3, imagem 1 %32 RYOBI P422 Body Replacement: passo 3, imagem 2 %32 RYOBI P422 Body Replacement: passo 3, imagem 3 %32
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: passo 4, imagem 1 %32 RYOBI P422 Body Replacement: passo 4, imagem 2 %32
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: passo 5, imagem 1 %32 RYOBI P422 Body Replacement: passo 5, imagem 2 %32 RYOBI P422 Body Replacement: passo 5, imagem 3 %32
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: passo 6, imagem 1 %32 RYOBI P422 Body Replacement: passo 6, imagem 2 %32
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: passo 7, imagem 1 %32 RYOBI P422 Body Replacement: passo 7, imagem 2 %32 RYOBI P422 Body Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: passo 8, imagem 1 %32 RYOBI P422 Body Replacement: passo 8, imagem 2 %32
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
Conclusão
John Lamanuzzi
Membro desde: 03/20/15
229 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-6, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-6, Duarte Spring 2015
UMASSD-DUARTE-S15S3G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,462
