Introdução
Small metal finger located beneath the memory door.
Ferramentas
Peças
Nenhum componente especificado.
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
2 outras pessoas concluíram este guia.
