Ir para o conteúdo principal
PowerA Enhanced Wireless Controller Action Buttons Replacement
Ayjah Montgomery
Ayjah Montgomery e 5 outros colaboradores
Última atualização em July 9, 2021
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
There is nothing more annoying than having the buttons on your wireless controller become stuck or broken. Wireless controllers for consoles can be quite expensive and can range from $50 USD all the way to $300 USD. If you are trying to save some money by extending the life of the action buttons on your PowerA Enhanced Wireless Controller, or if you want to learn how to clean your action buttons for appearance and performance purposes, then this is the repair for you. This repair is fairly easy, and no specific skills are required for completion. By following these steps you will be back on your console in no time with your newly fixed controller that you can tell all your friends about!
O que você precisa
Ferramentas
  1. PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 3 %32
    • Use the iFixit opening tool to lift the action button out from its place.
    • Pull the button out with your fingers.
    Where do you buy the buttons I haven’t been able to find anywhere that sells them
    Captain Chris Sherwood - Responder
Conclusão
Uma outra pessoa concluiu este guia.
Ayjah Montgomery
Membro desde: 10/10/19
408 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
2Comentários do guia
Where do you buy the buttons ?? I haven’t been able to find them
Where can I buy the buttons?
Justinas Maraulis - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 4,581
