Ir para o conteúdo principal
PlayStation Vita Wi-Fi Antenna Replacement
Brittany McCrigler
Brittany McCrigler e 3 outros colaboradores
Última atualização em January 4, 2019
20 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This guide takes you through the process of installing the Wi-Fi antenna on the PlayStation Vita. This is the white antenna cable on the right side of the wireless card.
O que você precisa
Peças
Ferramentas
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 2 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wi-Fi Antenna Replacement: passo 3, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 2 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wi-Fi Antenna Replacement: passo 5, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Wi-Fi Antenna Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wi-Fi Antenna Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Wi-Fi Antenna Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, imagem 2 %32
    • Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
    • Deroute the Wi-Fi antenna cable out of the black plastic casing.
  10. PlayStation Vita Wi-Fi Antenna Replacement: passo 10, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 10, imagem 2 %32
    • Using the pointy end of the spudger, gently pry the Wi-Fi antenna cable connector off of the left button board at the connection.
    • Remove the Wi-Fi antenna cable.
Conclusão
Brittany McCrigler
Membro desde: 03/05/12
89.748 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.526 guias
4 comentários
what about the ps vita slim 2000 model? ive got no wifi at all but cant see a teardown to find the wifi module
Keegan - Responder
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
samohvalov2010 - Responder
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
computer1up - Responder
^ okay that explains a lot, i thought i was missing parts in my PSV1000 wifi
Bronson - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 74
Ao todo: 8,903
