Ir para o conteúdo principal
Planet Eclipse Etha Eyes Replacement
Hannah Lancaster
Hannah Lancaster e 3 outros colaboradores
Última atualização em December 19, 2014
15 - 25 minutos
Moderado
Introdução
Ir para o passo 1
The Etha's Eyes determine there is a ball in the chamber before firing. This guide is useful for players who choose to upgrade their eyes, or for players who have a marker with broken eyes.
O que você precisa
Ferramentas
  1. Planet Eclipse Etha Eyes Replacement, Regulator: passo 1, imagem 1 %32 Planet Eclipse Etha Eyes Replacement, Regulator: passo 1, imagem 2 %32
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Eyes Replacement: passo 2, imagem 1 %32 Planet Eclipse Etha Eyes Replacement: passo 2, imagem 2 %32
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: passo 3, imagem 1 %32 Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: passo 3, imagem 2 %32
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Eyes Replacement: passo 4, imagem 1 %32
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Eyes Replacement: passo 5, imagem 1 %32 Planet Eclipse Etha Eyes Replacement: passo 5, imagem 2 %32
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Eyes Replacement, Frame: passo 6, imagem 1 %32 Planet Eclipse Etha Eyes Replacement, Frame: passo 6, imagem 2 %32
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Eyes Replacement: passo 7, imagem 1 %32 Planet Eclipse Etha Eyes Replacement: passo 7, imagem 2 %32
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Eyes Replacement: passo 8, imagem 1 %32
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Eyes Replacement, Eyes: passo 9, imagem 1 %32 Planet Eclipse Etha Eyes Replacement, Eyes: passo 9, imagem 2 %32
    • Use the 5/64" hex key to turn the screw counterclockwise.
    • Carefully remove the screw and place it off to the side.
    • Remove the panel and place it off to the side.
  10. Planet Eclipse Etha Eyes Replacement: passo 10, imagem 1 %32 Planet Eclipse Etha Eyes Replacement: passo 10, imagem 2 %32
    • Carefully flip the marker over.
    • Remove the screw and place it off to the side.
    • Carefully remove the panel and place it off to the side.
  11. Planet Eclipse Etha Eyes Replacement: passo 11, imagem 1 %32 Planet Eclipse Etha Eyes Replacement: passo 11, imagem 2 %32
    • Grip the marker with one hand and gently pull the eyes out with your other hand.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 10-42, Amido Fall 2014 Membro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,253
