Ir para o conteúdo principal
Planet Eclipse Etha Bolt O-rings Replacement
nicholasj6
nicholasj6 e 4 outros colaboradores
Última atualização em December 19, 2014
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
Sometimes, the O-ring seals in the Etha's bolt can get worn out and need to be replaced. Fortunately, Planet Eclipse designed this part of the marker to be taken apart and put back together with ease.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, imagem 2 %32 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, imagem 3 %32
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: passo 2, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 2, imagem 2 %32
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: passo 3, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 3, imagem 2 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 3, imagem 3 %32
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: passo 4, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 4, imagem 2 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 4, imagem 3 %32
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: passo 5, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 5, imagem 2 %32
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: passo 6, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 6, imagem 2 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 6, imagem 3 %32
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: passo 7, imagem 1 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 7, imagem 2 %32 Planet Eclipse Etha Bolt O-rings Replacement: passo 7, imagem 3 %32
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
Conclusão
Uma outra pessoa concluiu este guia.
nicholasj6
Membro desde: 10/14/14
261 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-42, Amido Fall 2014 Membro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 2,214
