Ir para o conteúdo principal
Picture Frame Matting Replacement
Leah
Leah e 3 outros colaboradores
Última atualização em May 24, 2023
30 minutos
Fácil
Replacing warped, damaged, or discolored matting in a picture frame is a relatively simple process that most people can accomplish at home with just a couple tools. This quick project can be completed in just under half an hour. Work carefully, as fixing matting involves handling glass.
O que você precisa
Ferramentas
  1. Picture Frame Matting Replacement, Picture Frame Matting: passo 1, imagem 1 %32
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: passo 2, imagem 1 %32
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: passo 3, imagem 1 %32 Picture Frame Matting Replacement: passo 3, imagem 2 %32
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: passo 4, imagem 1 %32
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: passo 5, imagem 1 %32
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: passo 6, imagem 1 %32 Picture Frame Matting Replacement: passo 6, imagem 2 %32
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: passo 7, imagem 1 %32
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: passo 8, imagem 1 %32 Picture Frame Matting Replacement: passo 8, imagem 2 %32
    • Rotate the backing clips under the frame to secure it.
Linha de Chegada
Leah
Membro desde: 01/20/23
160 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 286
