Ir para o conteúdo principal
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
Liam Casto
Liam Casto e 2 outros colaboradores
Última atualização em June 27, 2024
20 minutos
Difícil
Introdução
Ir para o passo 1
The power button is a switch used to turn the device on and off. The mode button changes how the toothbrush will vibrate. If you are having problems with either of these functions these buttons are likely the cause. There are small components in this guide so a steady hand is suggested to not damage other parts. Exercise caution when using the soldering iron as it is very hot.
O que você precisa
Ferramentas
Exibir mais…
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, imagem 2 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, imagem 3 %32
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 2, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 3, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 3, imagem 2 %32
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: passo 4, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: passo 4, imagem 2 %32
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 5, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 5, imagem 2 %32
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 6, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 6, imagem 2 %32
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Conclusão
Liam Casto
Membro desde: 04/01/24
354 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2024 Membro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 260
