Philips Sonicare ProtectiveClean 6500 Battery Replacement
Introdução
Ir para o passo 1If your Philips Sonicare ProtectiveClean 6500 isn’t powering on, has intermittent power, or not holding charge, use this guide to replace the battery.
O que você precisa
Pry the bottom cap away from the toothbrush body.
Pry the bottom cap away from the toothbrush body until it releases.
Remove the bottom cap by hand.
2Comentários do guia
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
