Pentax LX Top Cover (Rewind Side) Removal
Introdução
Vá para o passo 1Removing the top cover of the camera is the first step in many servicing jobs. It gives the user direct access to the ISO resistor which frequently needs to be cleaned.
Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
O que você precisa
Ferramentas
Place a thin tool in the rewind fork and unscrew the topside knob.
Remove the washer under the rewind knob.
Remove three #000 5.5 mm screws.
Remove exposure compensation dial assembly.
Remove washer.
Remove rubber seal.
Uma outra pessoa concluiu este guia.
