Ir para o conteúdo principal
Penny Board Trucks Replacement
Eduardo Ron
Eduardo Ron e um outro colaborador
Última atualização em June 9, 2021
15 minutos
Moderada
The trucks on a Penny board are an essential part of the board. They can get damaged in a variety of ways, which can lead to an unpleasant riding experience. Whether they get worn down or completely broken, they will need a replacement. Luckily, this repair is pretty simple so one can get back to skating in no time. For this repair, a skate tool will be required.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Penny Board Trucks Replacement, Trucks: passo 1, imagem 1 %32 Penny Board Trucks Replacement, Trucks: passo 1, imagem 2 %32
    • Use a skate tool to loosen the bolt in the wheel with an appropriately sized socket.
    • A skate tool will come with all the tools necessary to do this replacement from start to finish.
  2. Penny Board Trucks Replacement: passo 2, imagem 1 %32 Penny Board Trucks Replacement: passo 2, imagem 2 %32
    • Remove the wheel by lifting it from the truck.
    • Repeat this step for the other wheel.
  3. Penny Board Trucks Replacement: passo 3, imagem 1 %32 Penny Board Trucks Replacement: passo 3, imagem 2 %32
    • After completing the removal of both wheels, your board will look like this.
    • Place the skate tool over the bolt on the truck.
    • Maintain a good grip on the tool and use the Phillips screwdriver to loosen the nuts.
    • Repeat this step for all four screws.
  4. Penny Board Trucks Replacement: passo 4, imagem 1 %32 Penny Board Trucks Replacement: passo 4, imagem 2 %32
    • Lift the truck to remove it.
  5. Penny Board Trucks Replacement: passo 5, imagem 1 %32 Penny Board Trucks Replacement: passo 5, imagem 2 %32
    • Remove the screws from the board by pulling them out with your hands.
    • Use the Phillips screwdriver to loosen them more, if necessary.
Conclusão
Eduardo Ron
Membro desde: 02/17/21
171 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 608
