Ir para o conteúdo principal
Panasonic Lumix DMC-G5 LCD Replacement
Gabriel Gonzalez Jr
Gabriel Gonzalez Jr e 3 outros colaboradores
Última atualização em December 28, 2020
6 minutos
Fácil
Replacing the LCD face requires removal of a few small screws on the outside of the device.
O que você precisa
Ferramentas
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: passo 1, imagem 1 %32 Panasonic Lumix DMC-G5 LCD Replacement, LCD: passo 1, imagem 2 %32
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-G5 LCD Replacement: passo 2, imagem 2 %32
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: passo 3, imagem 1 %32
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-3, Kass Spring 2017 Membro de USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 2,107
