Ir para o conteúdo principal
Panasonic Lumix DMC-F7 Battery Replacement
Hormoz Tarevern
Hormoz Tarevern e 10 outros colaboradores
Última atualização em June 13, 2023
30 segundos
Fácil
Imagens inconsistentes
Melhor Introdução
Introdução
Ir para o passo 1
How to unlock the battery case and take out the battery.
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: passo 2, imagem 1 %32
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 7-35, Regan Winter 2011 Membro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 31
Ao todo: 2,450
