Panasonic ES-RF31 Battery Replacement
Introdução
Vá para o passo 1This guide shows you how to replace the battery of the Panasonic ES-RF31. You can find more specs here: http://www.panasonic.com/de/consumer/koe...
O que você precisa
Insert an opening tool into the gap
Gently remove the battery cover
7 outras pessoas executaram este guia.
4 comentários
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
