Pacific Image Electronics CS3600 Bulb Panel Replacement
Introdução
Ir para o passo 1Before you begin please be aware that you will be completely disassembling the device in order to get to the bulb inside. This will only require a Philips screw driver and able hands.
O que você precisa
Start by removing the 5 screws that are 5mm x 9mm located on the bottom of the device with a J1 screwdriver.
Uma outra pessoa concluiu este guia.
