Ir para o conteúdo principal
Ovation Acoustic Guitar String Replacement
Rachel Galvan
Rachel Galvan e 3 outros colaboradores
Última atualização em December 29, 2022
15 minutos
Fácil
If you have broken your Ovation Guitar string, use this guide to help you learn how to replace the string step by step. In this guide, you will learn how to not only replace the string, but learn how to implement a technique to prevent further guitar string breakage. Before using this guide, make sure inspect on how many strings are broken and if you have the correct strings.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Ovation Acoustic Guitar String Replacement, Guitar String: passo 1, imagem 1 %32
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: passo 2, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 2, imagem 2 %32
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: passo 3, imagem 1 %32
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: passo 4, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 4, imagem 2 %32
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: passo 5, imagem 1 %32
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: passo 6, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 6, imagem 2 %32 Ovation Acoustic Guitar String Replacement: passo 6, imagem 3 %32
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: passo 7, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 7, imagem 2 %32
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: passo 8, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 8, imagem 2 %32 Ovation Acoustic Guitar String Replacement: passo 8, imagem 3 %32
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: passo 9, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 9, imagem 2 %32
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
Linha de Chegada
Rachel Galvan
Membro desde: 04/07/21
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 870
