Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement
Introdução
Ir para o passo 1This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
O que você precisa
Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
Use the PH000 to remove the 7mm screw on the upper right corner of the device.
Uma outra pessoa concluiu este guia.
Um comentário
Thanks for the post. Do you know where to buy new switches?
