Ir para o conteúdo principal
Olympus Digital Camera TG-3 Lens Ring  Replacement
Natalia Morales
Natalia Morales e um outro colaborador
Última atualização em September 15, 2020
5 minutos
Moderado
Introdução
Ir para o passo 1
This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
O que você precisa
Ferramentas
  1. Olympus Digital Camera TG-3 Lens Ring  Replacement, Front Case: passo 1, imagem 1 %32
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Lens Ring  Replacement: passo 2, imagem 1 %32
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Lens Ring  Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Lens Ring  Replacement: passo 4, imagem 1 %32
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Lens Ring  Replacement: passo 5, imagem 1 %32
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Lens Ring  Replacement, Lens Ring: passo 6, imagem 1 %32
    • Twist the ring around the camera lens and pull it out.
Conclusão
Natalia Morales
Membro desde: 10/11/16
675 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-6, Leahy Fall 2016 Membro de USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 2,411
