Ir para o conteúdo principal
Nook Tablet Display Replacement
Michael Mooney
Michael Mooney e 7 outros colaboradores
Última atualização em 9 de jun de 2019
20 - 30 minutos
Difícil
Introdução
Ir para o passo 1
This guide will show easy ways to access the nook tablet visual display, replace the screen or reconnect the display if it is not working properly.
O que você precisa
Ferramentas
  1. Nook Tablet Display Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the Nook over.
  2. Nook Tablet Display Replacement: passo 2, imagem 1 %32 Nook Tablet Display Replacement: passo 2, imagem 2 %32
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
    Remove stickers covering T5 screws and remove screws
    badbyz - Responder
    Also, remove the mini SD card first or you may break it taking the back off.
    54pontiac - Responder
  3. Nook Tablet Display Replacement: passo 3, imagem 1 %32 Nook Tablet Display Replacement: passo 3, imagem 2 %32
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Display Replacement: passo 4, imagem 1 %32 Nook Tablet Display Replacement: passo 4, imagem 2 %32
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Display Replacement: passo 5, imagem 1 %32
    • Pull the back panel off the Nook.
  6. Nook Tablet Display Replacement, Screen Bezel: passo 6, imagem 1 %32 Nook Tablet Display Replacement, Screen Bezel: passo 6, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Display Replacement: passo 7, imagem 1 %32 Nook Tablet Display Replacement: passo 7, imagem 2 %32
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Display Replacement, Disconnect the Battery: passo 8, imagem 1 %32 Nook Tablet Display Replacement, Disconnect the Battery: passo 8, imagem 2 %32
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Display Replacement, Midframe: passo 9, imagem 1 %32
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Display Replacement: passo 10, imagem 1 %32 Nook Tablet Display Replacement: passo 10, imagem 2 %32
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Display Replacement, Display: passo 11, imagem 1 %32 Nook Tablet Display Replacement, Display: passo 11, imagem 2 %32
    • Orient the mother board as shown, so that the screen is facing downwards.
    • Grab the corner of the orange strip on the right side of the mother board as shown.
    • The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
    • The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
  12. Nook Tablet Display Replacement: passo 12, imagem 1 %32 Nook Tablet Display Replacement: passo 12, imagem 2 %32 Nook Tablet Display Replacement: passo 12, imagem 3 %32
    • The orange strip will still be attached at this point
    • Insert the end of a flat head screw driver between the connection of the strip and mother board and pry upward.
    • Grab the strip and gently pull upward to finish the disconnection.
  13. Nook Tablet Display Replacement: passo 13, imagem 1 %32 Nook Tablet Display Replacement: passo 13, imagem 2 %32
    • On the left side of the motherboard, you will see another orange strip, this one is taped down to the motherboard.
    • Remove the tape.
  14. Nook Tablet Display Replacement: passo 14, imagem 1 %32 Nook Tablet Display Replacement: passo 14, imagem 2 %32 Nook Tablet Display Replacement: passo 14, imagem 3 %32
    • After the tape has been removed, the strip will still be attached to the motherboard by the hinge pictured here.
    • Slide the tip of a flat head screwdriver under the hinge and pry the hinge upward.
    • The orange strip should now be detached from the mother board.
  15. Nook Tablet Display Replacement: passo 15, imagem 1 %32 Nook Tablet Display Replacement: passo 15, imagem 2 %32 Nook Tablet Display Replacement: passo 15, imagem 3 %32
    • The screen is adhered to the mother board at the screw holes marked
    • Break the adhesion by inserting the edge of a flat head screwdriver inbetween the motherboard and the pieces of the screen at the marked holes
    • Lift the screen from the display.
    Transfer the rainbow button and tape at the bottom of your old screen to the new screen if the new screen does not have one.
    Dave Snyder - Responder
Conclusão
12 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Michael Mooney
Membro desde: 09/26/12
291 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-4, Propen Fall 2012 Membro de Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Membros
Autoria de 14 guias
2Comentários do guia
Where can one get a replacement screen for the glow-light first model?
Hank - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 32,561
