Nokia Lumia 625 Battery Replacement
Introdução
Ir para o passo 1How to disassemble Nokia Lumia 625 to change / replace the battery.
O que você precisa
Vídeo de Apresentação
Turn off the phone and remove the back cover.
Remove any installed SIM or memory card.
Use a screwdriver Torx T5 and remove the 8x black screws.
Disconnect the battery connector.
Use a plastic tool and unstuck the battery.
Look at the picture to see where is the battery adhesive sticker.
11 outras pessoas executaram este guia.
2Comentários do guia
Simple
Très compréhensible
Efficace
Bravo
