Ir para o conteúdo principal
Nokia Lumia 1020 Screen Replacement
O que você precisa
  1. Nokia Lumia 1020 Screen Replacement, Screen: passo 1, imagem 1 %32 Nokia Lumia 1020 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Screen Replacement: passo 2, imagem 1 %32 Nokia Lumia 1020 Screen Replacement: passo 2, imagem 2 %32 Nokia Lumia 1020 Screen Replacement: passo 2, imagem 3 %32
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Screen Replacement: passo 3, imagem 1 %32 Nokia Lumia 1020 Screen Replacement: passo 3, imagem 2 %32 Nokia Lumia 1020 Screen Replacement: passo 3, imagem 3 %32
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Screen Replacement: passo 4, imagem 1 %32 Nokia Lumia 1020 Screen Replacement: passo 4, imagem 2 %32 Nokia Lumia 1020 Screen Replacement: passo 4, imagem 3 %32
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
Conclusão
4 outras pessoas executaram este guia.
Sydney Hostelley
Membro desde: 02/15/18
599 Reputação
5 Guias de autoria
Equipe
USF Tampa, Team S1-G4, Leahy Spring 2018 Membro de USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
4 Membros
10 Guias de autoria
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 1,785
