Ir para o conteúdo principal
Nissan Versa Note Media Display System Replacement
Matthew do Santos-Zounon
Matthew do Santos-Zounon e um outro colaborador
Última atualização em December 9, 2020
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
If you’d like to replace your Nissan Versa Note’s media/navigation/radio system, this guide will show you the removal process. Ensure that your car’s engine and battery (accessory mode) are off before trying the replacement. If you plan on discarding the media system, you should locate your local recycling center as this device should not be simply thrown into the garbage.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Nissan Versa Note Media Display System Replacement, Media Display System: passo 1, imagem 1 %32
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: passo 2, imagem 1 %32
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: passo 3, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 3, imagem 2 %32
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: passo 4, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 4, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 4, imagem 3 %32
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: passo 5, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 5, imagem 2 %32
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: passo 6, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 6, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 6, imagem 3 %32
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: passo 7, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 7, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 7, imagem 3 %32
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: passo 8, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 8, imagem 2 %32
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: passo 9, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 9, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 9, imagem 3 %32
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
    Very clear instructions. Thanks
    TPaul - Responder
Conclusão
1Comentário do guia
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 90
Ao todo: 4,339
