Nissan Versa Note Media Display System Replacement
Introdução
Ir para o passo 1If you’d like to replace your Nissan Versa Note’s media/navigation/radio system, this guide will show you the removal process. Ensure that your car’s engine and battery (accessory mode) are off before trying the replacement. If you plan on discarding the media system, you should locate your local recycling center as this device should not be simply thrown into the garbage.
O que você precisa
Ferramentas
Exibir mais…
