Ir para o conteúdo principal
Nishiki Aero II Front Inner Tube Replacement
Tobias Elder
Tobias Elder e 6 outros colaboradores
Última atualização em December 15, 2023
10 - 20 minutos
Fácil
Precisa de melhores imagens
Faltando Passos
Introdução
Ir para o passo 1
Sometimes, your tire's inner tube just goes flat. To fix that, you either buy a new one or patch the faulty one. Either way, you'll have to get the tube out of the tire, and this guide shows you how.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Nishiki Aero II Front Inner Tube Replacement, Removing Road Bike Front Wheel: passo 1, imagem 1 %32
    • Turn the bike upside down.
  2. Nishiki Aero II Front Inner Tube Replacement: passo 2, imagem 1 %32
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Front Inner Tube Replacement: passo 3, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement: passo 3, imagem 2 %32
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Front Inner Tube Replacement: passo 4, imagem 1 %32
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Front Inner Tube Replacement: passo 5, imagem 1 %32
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: passo 6, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: passo 6, imagem 2 %32
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Front Inner Tube Replacement: passo 7, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement: passo 7, imagem 2 %32 Nishiki Aero II Front Inner Tube Replacement: passo 7, imagem 3 %32
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Front Inner Tube Replacement: passo 8, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement: passo 8, imagem 2 %32
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Front Inner Tube Replacement: passo 9, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement: passo 9, imagem 2 %32 Nishiki Aero II Front Inner Tube Replacement: passo 9, imagem 3 %32
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Front Inner Tube Replacement: passo 10, imagem 1 %32 Nishiki Aero II Front Inner Tube Replacement: passo 10, imagem 2 %32 Nishiki Aero II Front Inner Tube Replacement: passo 10, imagem 3 %32
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
  11. Nishiki Aero II Front Inner Tube Replacement, Front Inner Tube: passo 11, imagem 1 %32
    • Now that the tire and tube are off of the rim, gently pull the tube out of the tire.
    • Be sure to pull gently, as the tube could potentially end up adhered to the inside of the tire.
  12. Nishiki Aero II Front Inner Tube Replacement: passo 12, imagem 1 %32
    • Now, you've separated your tube, tire and rim.
    • To replace the tube, follow these instructions in reverse order using the new or patched tube.
    • Remember to inflate just a little bit of air into the tube before you try to install it, as that makes the process go much smoother.
Conclusão
Tobias Elder
Membro desde: 04/25/13
113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-53, Johann Spring 2013 Membro de Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,539
