Ir para o conteúdo principal
Nintendo Switch Lite Screen Replacement
O que você precisa
  1. Nintendo Switch Lite Screen Replacement, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    All my screws got stripped any ideas on how to remove?
    Almost A Mammal - Responder
    A Y0 screwdriver seemed to work better for me.
    Tommy Morrill - Responder
    What type of screw driver do I use to un screw the screws and which way
    Luca Capito - Responder
    Y 0.6 was all I had but it seemed to fit perfectly
    Trevor - Responder
    Like really snug? I've gotten away with using Drivers either bigger or smaller but I hate doing it. But if 0.6 is the exact size I need, then I'll get that. I don't wanna strip my client's Switch Lite's screws.
    Vincent Valodze -
  2. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: passo 2, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: passo 2, imagem 2 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    I accidentally stripped the back screw and now I can't open it. I removed all the other screws. What should I do?
    tiggytiger555 - Responder
  3. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: passo 3, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: passo 3, imagem 2 %32
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: passo 4, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: passo 4, imagem 2 %32
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Screen Replacement, Twist to release the clips: passo 5, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Twist to release the clips: passo 5, imagem 2 %32
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: passo 6, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: passo 6, imagem 2 %32
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Screen Replacement: passo 7, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 7, imagem 2 %32
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Screen Replacement, Remove the back panel: passo 8, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the back panel: passo 8, imagem 2 %32 Nintendo Switch Lite Screen Replacement, Remove the back panel: passo 8, imagem 3 %32
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Screen Replacement, Remove the shield plate: passo 9, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    There are four screws instead of three mentioned
    Khurram Chaudry - Responder
    it doesnt mention 3 anywhere, and it labels all four
    Ezi - Responder
    With how easy it seems to be to do serious damage with the next few steps, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    Nate - Responder
    i stripped a &&^&^$^ screw
    SpongebobFan254 - Responder
    Well I actually removed the screw right next to the 4.5 screw. I did not realize it till my son showed me why the plate wouldn't release. Ha ha, it's funny now but yeah not a big deal. I could have bent it badly assuming I took all screws out though. For anyone reading this before going in. 👍
    Toastninja - Responder
  10. Nintendo Switch Lite Screen Replacement: passo 10, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 10, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 10, imagem 3 %32
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    You may need to replace the thermal paste on the heat sink.
    ahoz28 - Responder
    What type of Thermal Paste would you guys recommend? I clicked on the picture but nothing.
    Vincent Valodze - Responder
    Personnaly i use some Mx-6 from Artic, really good quality/price, never have to complain.
    Nothing -
  11. Nintendo Switch Lite Screen Replacement, Disconnect the battery: passo 11, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the battery: passo 11, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    The clip broke off when trying to remove this cable. Audio only works through headphones and the display now won’t turn on after the clip broke. Does anyone know where I could get a clip or how I could fix it without it?
    Alexz Zepeda - Responder
    Mi è successa la stessa cosa è non so come ripararla! Chissà se c’è un modo!
    Paolo De Falco -
  12. Nintendo Switch Lite Screen Replacement: passo 12, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 12, imagem 2 %32
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    I turned the unit off beforehand, I used tweezers just like the instructions said (ifixit branded) , my device sparked and now it won’t turn back on
    User Service - Responder
    The flap came off is it important or is there a way t fix it?
    Jose Cruz R Rangel Cordero - Responder
    We're you able to get it working without the white flap? My screen is not working after putting it back together and i noticed this white flap was falling off
    Jimmy “Ghost” Trost -
    Did you get it working without the white flap? Everything on the switch works fine except for audio going through headphones and the display not turning on.
    Alexz Zepeda -
    do not use metal sharp pointed tweezers! you will rip your ribbon cable. Use the inside of a Bic type pen or something else dull and plastic to pull the cable away by putting the pen part where the first bend is.
    Christopher Bales (C.J.) - Responder
    Anyone figure out how to fix this? my device shorted in this step.
    Acord - Responder
    Maybe tape the Tweezers or smear some hot glue on them to insulate them to save you time and money.
    Maybe put all the Warnings at the start of the guide as well. We fix it geeks tend to get excited when fixing things 😁
  13. Nintendo Switch Lite Screen Replacement: passo 13, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 13, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Caution the connector may not be properly soldered onto the motherboard. For me it snapped off the pins and now have to find a place to get that fixed if even possible. may have bricked it.
    Craig Osman - Responder
    Yup, broke the connector right off the motherboard. Thanks, ifixit -_-
    Justin Kerr - Responder
    I backed out when I reached this point. I couldn't risk damaging it. Do u just need to pull it up? Did you mean that it might have been soldered shut below?
    Jannalyzer - Responder
    You should just need to pull straight up, but make sure you’re pulling on the wires or the gray plug—do not pull on the black socket or it can snap off of the motherboard.
    Adam O'Camb -
    I pulled straight up from the south side on under 2 or three wires and held down the device as I pulled and the gray connector disconnected from the black connector on the Switch. Just be careful at this part.
    Jon - Responder
    With how easy it seems to be to do serious damage at this point, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    Nate - Responder
    just broke my connector... ifixit PLEASE put a warning on how fragile the solder on this connector is.
    Nate Mascis - Responder
    Note for this step, you do not need to apply a lot of force. I used two tools here: small screwdriver to hold down the black base, and one side of fine-tipped tweezers to get under all 3 wires. Gently, push down on the tweezers to push the wires upwards, which should force the gray connector up and off the base. It did not take a lot of force. Take your time and it will be fine. Again, like others have said, do NOT pull or pry up the black base.
    Christopher Gillett - Responder
  14. Nintendo Switch Lite Screen Replacement, Remove the heat sink: passo 14, imagem 1 %32
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    When reassembling, the foam may fold down between the fan and heatsink, blocking airflow. Gently lift the foam back up on top of the fan. The adhesive film should hold the foam together.
    Kean Stump - Responder
    Is removing the heat sink absolutely necessary?
    Clark Aulden - Responder
    It’s not necessary, but it makes it much easier to remove and replace the game card reader, since the heat sink partially covers the connector.
    Craig Lloyd -
    Not really…….. I never remove it. It slides out quite easily once disconnected.
    Alan Sears - Responder
    What do you do if these screws are stripped? They strip easily
    Whatever - Responder
  15. Nintendo Switch Lite Screen Replacement: passo 15, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Non le tre ventole ma le tre viti
    Cristiano Minchillo - Responder
    Grazie per avercelo segnalato! Ho apportato la modifica. iFixit è una wiki, quindi ogni utente può modificare le pagine: se trovi altri errori in futuro, sentiti libero di fare la modifica tu stesso!
    Sara Balestra -
  16. Nintendo Switch Lite Screen Replacement: passo 16, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 16, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 16, imagem 3 %32
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    16.5 remove cartridge / headphones jack……….
    Calvin Martin - Responder
    I've read that there are different ways to apply thermal paste, which should I use?
    Kai B - Responder
    My kit did not come with thermal paste..
    Bryan Donovan - Responder
  17. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: passo 17, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: passo 17, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  18. Nintendo Switch Lite Screen Replacement: passo 18, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  19. Nintendo Switch Lite Screen Replacement: passo 19, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 19, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 19, imagem 3 %32
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  20. Nintendo Switch Lite Screen Replacement, Remove the right trigger button assembly: passo 20, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
    I think a whole step to remove the game card reader and speaker jack was skipped here…
    ConfusedAzn Random - Responder
    yes, just found that sadly these comments do not show unless we click on the , which is unhelpful
    Micheal speed -
    also, you need to remove the left trigger button
    Micheal speed - Responder
  21. Nintendo Switch Lite Screen Replacement: passo 21, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 21, imagem 2 %32
    • Remove the right trigger button assembly.
  22. Nintendo Switch Lite Screen Replacement: passo 22, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 22, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  23. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: passo 23, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: passo 23, imagem 2 %32 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: passo 23, imagem 3 %32
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  24. Nintendo Switch Lite Screen Replacement, Disconnect the fan cable: passo 24, imagem 1 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  25. Nintendo Switch Lite Screen Replacement: passo 25, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 25, imagem 2 %32
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    There’s a step missing after this to remove the screws that hold the orange game cartridge slot. Those 7 screws have to be undone and the ribbon unclipped first before moving on to the next step.
    Heather Thrasher - Responder
    Good Looking out!
    Joshua Hinchey -
  26. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: passo 26, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: passo 26, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
    skipped a step or two about removing the golden piece in the photo above, and the other little board
    Eddy Whitaker - Responder
    If I broke the clasp on the ZIF connector can I elec tape it down?
    kevin miller - Responder
    What did you do to fix it if the ZIF connector broke?? Mine did too and I worry that is why the screen won’t turn on now
    Amber Smith -
    Missing the card reader + audio jack board removal. Just remove the 4 screws around the audio jack + 3 screws around the card reader and disconnect the ZIF connector from the motherboard.
    Guillaume Turchini - Responder
  27. Nintendo Switch Lite Screen Replacement: passo 27, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 27, imagem 2 %32
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  28. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: passo 28, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: passo 28, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    Can I electrical tape this down if I broke the clasp?
  29. Nintendo Switch Lite Screen Replacement: passo 29, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 29, imagem 2 %32
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  30. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: passo 30, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: passo 30, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  31. Nintendo Switch Lite Screen Replacement: passo 31, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 31, imagem 2 %32
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  32. Nintendo Switch Lite Screen Replacement, Remove the motherboard assembly: passo 32, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
    how to get the c port off
    Dustin Cronk - Responder
    When re-assembling, be sure the fan cable (step 25) is completely pulled through prior to tightening the screw that’s right next to it.
    John Glaeser - Responder
  33. Nintendo Switch Lite Screen Replacement: passo 33, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 33, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 33, imagem 3 %32
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  34. Nintendo Switch Lite Screen Replacement, Remove the right joystick: passo 34, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  35. Nintendo Switch Lite Screen Replacement: passo 35, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 35, imagem 2 %32
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
    Where are parts for the right joystick?
    John - Responder
  36. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: passo 36, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the left speaker module: passo 36, imagem 2 %32
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
    pulled from the connector, not the wires, and ended up ripping them off the connector anyways since it encountered tension from the other end (the gray chamber on the left)
    consider doing step 15 before pulling the wire, just in case.
    Phillipe Legenda - Responder
    Why even disconnect this cable. Not worth the risk leave it connected to daughter board.
    Michael McNally - Responder
    while doing this I ripped the pad on the circuit board off. Should i risk trying to repair it or should i just try to go without the speaker???
    sarah.carney203 - Responder
    I also accidentally ripped off the connector, disabling the left speaker. However, that will not break any functionality of the switch. The right speaker works just fine on its own (just remember to turn the audio to mono in system settings) and I was successfully able to replace the joystick. Although the audio quality is a little bit depleted, you barely notice it if you turn up the volume a little, and I think being able to actually MOVE FORWARD in my games is a better plus than having louder, stereo, audio.
    Jonathan Maye - Responder
    Went to pull the speaker connector and it pulled right off the motherboard. Would not come loose.
    putnamjerome4 - Responder
    I'm gonna echo what others said here and suggest that you skip this step. After you complete Step 15, you can just move the speakers enough with your fingers to complete Step 26, which involves a screw half underneath it.
    Regarding the ribbon cable in Step 17 & Step 18, you can honestly use your fingers if they're small enough. The ribbon cable is wide enough for you to press down on it a little and slide it out bit by bit.
    Overall, this makes the disassembly and eventual reassembly process easier and lets you avoid running the risk of damaging or completely tearing out the wires, like I almost did.
    ThatDerpGuy - Responder
    I too tore the connector off the board. I didn't read the comments first :(. Take the advise and leave the connection
    Bob - Responder
    Removing the screw from 37 is enough to give you space to remove the board, I honestly think you shouldn't try to remove this connector.
    Romaric Dgp - Responder
    Unfortunately, I had to reinstall multiple daughterboards on the same Switch Lite. I strongly recommend orienting your straight tweezers with ridges (like the ones in the picture) perpendicular to the device. Grab the plastic connector with the tip of the tweezers from the top. It makes inserting and removing this connection significantly easier.
    Albino Digits - Responder
  37. Nintendo Switch Lite Screen Replacement: passo 37, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
  38. Nintendo Switch Lite Screen Replacement: passo 38, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 38, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 38, imagem 3 %32
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
    Pulling the lower screw on the speaker assembly gave me a little more wiggle room to get it out without damaging the flat cable.
    Spacer - Responder
  39. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: passo 39, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: passo 39, imagem 2 %32
  40. Nintendo Switch Lite Screen Replacement: passo 40, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 40, imagem 2 %32
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
    Reconnecting this part was touchy. After initial reassembly, the Switch did not power on. Even though this looked like it was correctly connected, pulling it out and reconnecting it solved the problem.
    John - Responder
  41. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: passo 41, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: passo 41, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
  42. Nintendo Switch Lite Screen Replacement: passo 42, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 42, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 42, imagem 3 %32
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
  43. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: passo 43, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the volume buttons: passo 43, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the volume buttons.
  44. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: passo 44, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: passo 44, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
  45. Nintendo Switch Lite Screen Replacement: passo 45, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 45, imagem 2 %32
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
    The connector for my left joystick broke. Is there a way to fix it?
    Christopher Shackelford - Responder
    How badly did it broke?
    Daniele Carminati -
  46. Nintendo Switch Lite Screen Replacement, Remove the left trigger button assembly: passo 46, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
  47. Nintendo Switch Lite Screen Replacement: passo 47, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 47, imagem 2 %32
    • Remove the left trigger button assembly.
  48. Nintendo Switch Lite Screen Replacement, Remove the daughterboard: passo 48, imagem 1 %32
    • Two 4.5 mm screws
    • Two 6 mm screws
    The two 4.5 mm screws were very difficult to remove here and ended up getting stripped. I CANNOT remove them, help!
    Sara Rouse- Barker - Responder
  49. Nintendo Switch Lite Screen Replacement: passo 49, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 49, imagem 2 %32
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
    Stop here if repairing Switch Lite for joycon drift. After removing daughter card you can see the bottom of the joystick. This thin metal actually bends during use causing bad connection of joystick. If you cut out a business card the same size as the joycon and put it on the bottom of the joystick it gives the metal enough backing to fix the issue. I used two layers with just a small bit of glue stick to adhere it. Put it all back together and you will find your issue is fixed.
    That's great, but it's only Temporary.
    You may as well put a New Stick in (preferably Hall Effect) after going through Hell to open the darn thing.
    If you do choose the cardboard route, you may as well clean the innards of the Joystick, BUUUT, it's not easy getting the Joystick back together.
    Vincent Valodze -
    Daughterboard. That's a new one for me.
  50. Nintendo Switch Lite Screen Replacement, Remove the left joystick: passo 50, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
  51. Nintendo Switch Lite Screen Replacement: passo 51, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 51, imagem 2 %32 Nintendo Switch Lite Screen Replacement: passo 51, imagem 3 %32
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
    During reassembly when putting the screws back in, slowly turn them CCW until you feel it drop into its thread. You will never crossthread them by doing this.
    Robert Hale - Responder
  52. Nintendo Switch Lite Screen Replacement, Unfasten the midframe assembly: passo 52, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH000 driver to remove the four screws securing the midframe assembly:
    • Three 2.5 mm screws
    • One 6 mm screw
  53. Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: passo 53, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: passo 53, imagem 2 %32 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: passo 53, imagem 3 %32
    • Use a spudger to pry the midframe assembly up until you can grip it with your fingers.
    • Grip the midframe assembly and pull up to remove it.
  54. Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: passo 54, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: passo 54, imagem 2 %32
    • Remove any remaining buttons that are loose in the frame.
  55. Nintendo Switch Lite Screen Replacement, Heat the left edge: passo 55, imagem 1 %32
    • Flip the frame over so the screen is facing up.
    • Heat an iOpener and apply it to the left edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer on the Low heat setting.
    • If you're using a hair dryer, only heat the screen a few seconds at a time or you may warp the plastic shell.
  56. Nintendo Switch Lite Screen Replacement, Insert an opening pick: passo 56, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Insert an opening pick: passo 56, imagem 2 %32 Nintendo Switch Lite Screen Replacement, Insert an opening pick: passo 56, imagem 3 %32
    • Lightly bend the left side of the frame away from the screen to create a gap in the bottom left corner.
    • If you're having difficulty creating a gap, reapply a heated iOpener for two minutes and try again.
    • Insert an opening pick in the gap.
    • Don't insert your pick more than 3 mm to avoid damaging the screen.
  57. Nintendo Switch Lite Screen Replacement, Slice the left adhesive: passo 57, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Slice the left adhesive: passo 57, imagem 2 %32
    • Throughout this repair, don't insert your pick more than 3 mm to avoid damaging the screen.
    • Slide the opening pick along the left edge.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  58. Nintendo Switch Lite Screen Replacement, Heat the top edge: passo 58, imagem 1 %32
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    • You can also use a hair dryer, but remember not to heat the screen more than a few seconds at a time.
  59. Nintendo Switch Lite Screen Replacement, Slice the top adhesive: passo 59, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Slice the top adhesive: passo 59, imagem 2 %32
    • Rotate the opening pick around the top left corner.
  60. Nintendo Switch Lite Screen Replacement: passo 60, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 60, imagem 2 %32
    • Slide the opening pick along the top edge.
    • Leave the opening pick inserted in the top right corner.
  61. Nintendo Switch Lite Screen Replacement, Heat the right edge: passo 61, imagem 1 %32
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  62. Nintendo Switch Lite Screen Replacement, Slice the right adhesive: passo 62, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Slice the right adhesive: passo 62, imagem 2 %32
    • Rotate the opening pick around the top right corner.
  63. Nintendo Switch Lite Screen Replacement: passo 63, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 63, imagem 2 %32
    • Slide the opening pick along the right edge.
    • Leave the opening pick inserted in the bottom right corner.
  64. Nintendo Switch Lite Screen Replacement, Heat the bottom edge: passo 64, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  65. Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: passo 65, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: passo 65, imagem 2 %32
    • Rotate the opening pick around the bottom right corner.
  66. Nintendo Switch Lite Screen Replacement: passo 66, imagem 1 %32 Nintendo Switch Lite Screen Replacement: passo 66, imagem 2 %32
    • Slide the opening pick along the bottom edge.
  67. Nintendo Switch Lite Screen Replacement, Separate the adhesive: passo 67, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Separate the adhesive: passo 67, imagem 2 %32
    • Grip the frame and push up on the underside of the screen's left edge to separate the adhesive securing it.
  68. Nintendo Switch Lite Screen Replacement, Remove the screen: passo 68, imagem 1 %32 Nintendo Switch Lite Screen Replacement, Remove the screen: passo 68, imagem 2 %32 Nintendo Switch Lite Screen Replacement, Remove the screen: passo 68, imagem 3 %32
    • The digitizer cables prevent the screen from being lifted straight up from the frame.
    • Lift the left side of the screen to a 45-degree angle and remove it.
    • If the screen is still stuck to the frame, slide an opening pick around the perimeter and try again.
    • During reassembly, follow this guide to replace the screen adhesive.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
17 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
94.557 Reputação
Autoria de 662 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
2 comentários
Thanks for your guide - it was very helpful, first time I took screen off without breaking it off :). I also bought the iFixit kit with the heat pad. I can now see that the trick was not so much a lot of heat, but heat evenly along the whole side
Angelo Felix - Responder
omg you are a lifesaver thank you so much
Adien Richards - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 66
Últimos 7 dias: 432
Últimos 30 dias: 1,739
Duração total: 35,269
