Ir para o conteúdo principal
Nikon D40 LCD Screen Replacement
Gerik Kubiak
Gerik Kubiak e 2 outros colaboradores
Última atualização em 20 de mar de 2014
30 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
LCD screens are known to shatter when dropped. In this guide you will replace the LCD screen that is on the inside of the camera.
O que você precisa
Ferramentas
Exibir mais…
  1. Nikon D40 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 LCD Screen Replacement: passo 2, imagem 1 %32 Nikon D40 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 LCD Screen Replacement: passo 4, imagem 1 %32
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32
    • Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
  6. Nikon D40 LCD Screen Replacement: passo 6, imagem 1 %32
    • Detach the ribbon cables on the LCD casing.
  7. Nikon D40 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Be sure to look at the picture to make sure you are removing the correct piece of metal. There should be no glue holding the correct piece to the frame.
  8. Nikon D40 LCD Screen Replacement: passo 8, imagem 1 %32
    • You should now be able to remove the LCD screen. Replace it with a new screen.
Conclusão
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Gerik Kubiak
Membro desde: 01/21/14
327 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-19, Maness Winter 2014 Membro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 6,487
