Nikon Coolpix S7000 Shutter Button Replacement
Introdução
Ir para o passo 1If you notice the camera shutter button isn't depressing or is too easily pressed, you may have to adjust or replace the button or button assembly. This guide will show you how to repair the individual parts that comprise the shutter button.
O que você precisa
Ferramentas
Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
Screw locations.
