Introdução
If you've noticed your buttons are no longer functioning, or missing altogether, it may be time to replace them. This guide will take you through the steps to replace the navigation buttons for this particular camera.
O que você precisa
Turn the camera so the bottom side is facing you. Locate the two 40 mm, Phillips head screws on it.
Using a Philips #J000 Screwdriver, carefully remove each screw.
Locate the 30 mm, Phillips head screw in the upper-left corner of the midplate and remove it.
There are two 30 mm, Phillips head screws on the bottom side of the midframe. Locate and unscrew them.
There are two more 30 mm, Phillips head screws hidden on the right side of the midframe. Locate them and carefully remove them.
Once all the screws have been removed, gently lift the midframe to reveal the circuit.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Didn't show navigation button replacement? I believe two of the screws (I forget which) from Steps 1-3 are different lengths.
