Ir para o conteúdo principal
Nest Cam Side Snap Locks Replacement
Lisa Langley
Lisa Langley e 3 outros colaboradores
Última atualização em May 7, 2024
35 - 40 minutos
Moderado
Introdução
Ir para o passo 1
The Nest Cam needs to be mounted on a stand for optimal posistioning. If your Nest Cam refuses to secure itself to the stand or falls off often, the side snap locks may have weakened or broken and need to be replaced.
O que você precisa
Ferramentas
Exibir mais…
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: passo 1, imagem 1 %32
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: passo 2, imagem 1 %32 Nest Cam Side Snap Locks Replacement: passo 2, imagem 2 %32 Nest Cam Side Snap Locks Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: passo 3, imagem 1 %32 Nest Cam Side Snap Locks Replacement: passo 3, imagem 2 %32 Nest Cam Side Snap Locks Replacement: passo 3, imagem 3 %32
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: passo 4, imagem 1 %32 Nest Cam Side Snap Locks Replacement: passo 4, imagem 2 %32
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
Conclusão
Lisa Langley
Membro desde: 02/24/16
210 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Leahy Spring 2016 Membro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 2,036
