Ir para o conteúdo principal
Motorola Edge (2022) Screen Replacement
O que você precisa
  1. Motorola Edge (2022) Screen Replacement, Remove the SIM card tray: passo 1, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the SIM card tray: passo 1, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Remove the SIM card tray: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the sim card tray hole to eject the SIM card tray.
    • Use your fingers or tweezers to remove the SIM card tray.
    Pergunte ao FixBot
    Comentar
  2. Motorola Edge (2022) Screen Replacement, Heat the right edge: passo 2, imagem 1 %32
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  3. Motorola Edge (2022) Screen Replacement, Separate the right adhesive: passo 3, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Separate the right adhesive: passo 3, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Separate the right adhesive: passo 3, imagem 3 %32
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    Pergunte ao FixBot
    Comentar
  4. Motorola Edge (2022) Screen Replacement, Slice the right adhesive: passo 4, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Slice the right adhesive: passo 4, imagem 2 %32
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  5. Motorola Edge (2022) Screen Replacement, Heat the bottom edge: passo 5, imagem 1 %32
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
    Pergunte ao FixBot
    Comentar
  6. Motorola Edge (2022) Screen Replacement, Slice the bottom right corner adhesive: passo 6, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Slice the bottom right corner adhesive: passo 6, imagem 2 %32
    • Rotate the pick around the bottom right corner to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  7. Motorola Edge (2022) Screen Replacement: passo 7, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 7, imagem 2 %32
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  8. Motorola Edge (2022) Screen Replacement: passo 8, imagem 1 %32
    • Apply a heated iOpener to the back cover's left edge for two minutes.
    Pergunte ao FixBot
    Comentar
  9. Motorola Edge (2022) Screen Replacement: passo 9, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 9, imagem 2 %32
    • Rotate the pick around the bottom left corner to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  10. Motorola Edge (2022) Screen Replacement: passo 10, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 10, imagem 2 %32
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  11. Motorola Edge (2022) Screen Replacement: passo 11, imagem 1 %32
    • Apply a heated iOpener to the back cover's top edge for two minutes.
    Pergunte ao FixBot
    Comentar
  12. Motorola Edge (2022) Screen Replacement: passo 12, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 12, imagem 2 %32
    • Rotate the pick around the top left corner to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  13. Motorola Edge (2022) Screen Replacement: passo 13, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 13, imagem 2 %32
    • Slide the pick along the top edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  14. Motorola Edge (2022) Screen Replacement, Remove the back cover: passo 14, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the back cover: passo 14, imagem 2 %32
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
    Pergunte ao FixBot
    Comentar
  15. Motorola Edge (2022) Screen Replacement, Separate the camera bezel adhesive: passo 15, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Separate the camera bezel adhesive: passo 15, imagem 2 %32
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  16. Motorola Edge (2022) Screen Replacement: passo 16, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 16, imagem 2 %32
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
    Pergunte ao FixBot
    Comentar
  17. Motorola Edge (2022) Screen Replacement, Remove the camera bezel: passo 17, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the camera bezel: passo 17, imagem 2 %32
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
    Pergunte ao FixBot
    Comentar
  18. Motorola Edge (2022) Screen Replacement, Detach the left wireless charging coil tape: passo 18, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Detach the left wireless charging coil tape: passo 18, imagem 2 %32
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
    Pergunte ao FixBot
    Comentar
  19. Motorola Edge (2022) Screen Replacement, Detach the right wireless charging coil tape: passo 19, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Detach the right wireless charging coil tape: passo 19, imagem 2 %32
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
    Pergunte ao FixBot
    Comentar
  20. Motorola Edge (2022) Screen Replacement: passo 20, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 20, imagem 2 %32
    • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
    Pergunte ao FixBot
    Comentar
  21. Motorola Edge (2022) Screen Replacement: passo 21, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 21, imagem 2 %32
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
    Pergunte ao FixBot
    Comentar
  22. Motorola Edge (2022) Screen Replacement: passo 22, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 22, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 22, imagem 3 %32
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
    Pergunte ao FixBot
    Comentar
  23. Motorola Edge (2022) Screen Replacement, Remove the motherboard cover: passo 23, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the motherboard cover: passo 23, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Remove the motherboard cover: passo 23, imagem 3 %32
    • Slowly pull the motherboard cover up and away from the phone and remove it.
    Pergunte ao FixBot
    Comentar
  24. Motorola Edge (2022) Screen Replacement, Move the graphite film: passo 24, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Move the graphite film: passo 24, imagem 2 %32
    • Use your fingers to move the graphite film that covers the battery out of the way.
    Pergunte ao FixBot
    Comentar
  25. Motorola Edge (2022) Screen Replacement, Disconnect the battery: passo 25, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the battery: passo 25, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  26. Motorola Edge (2022) Screen Replacement, Unfasten the daughterboard cover: passo 26, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Unfasten the daughterboard cover: passo 26, imagem 2 %32
    • Use a Phillips screwdriver to remove the five screws securing the daughterboard cover:
    • Four 4.1 mm screws
    • One 3 mm screw
    Pergunte ao FixBot
    Comentar
  27. Motorola Edge (2022) Screen Replacement, Release the daughterboard cover clips: passo 27, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Release the daughterboard cover clips: passo 27, imagem 2 %32
    • Insert a spudger under the daughterboard cover on the bottom right corner of the phone.
    • Pry up with the spudger to release the clips securing the cover.
    Pergunte ao FixBot
    Comentar
  28. Motorola Edge (2022) Screen Replacement, Remove the daughterboard cover: passo 28, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the daughterboard cover: passo 28, imagem 2 %32
    • Use your fingers or tweezers to remove daughterboard cover.
    Pergunte ao FixBot
    Comentar
  29. Motorola Edge (2022) Screen Replacement, Disconnect the interconnect cable: passo 29, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the interconnect cable: passo 29, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
    Pergunte ao FixBot
    Comentar
  30. Motorola Edge (2022) Screen Replacement: passo 30, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 30, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 30, imagem 3 %32
    • Use your fingers or tweezers to peel back and remove the tape on the fingerprint sensor cover.
    • Set the tape aside for reassembly.
    Pergunte ao FixBot
    Comentar
  31. Motorola Edge (2022) Screen Replacement, Unfasten the daughterboard: passo 31, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Unfasten the daughterboard: passo 31, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3 mm screws:
    • One screw securing the fingerprint sensor cover.
    • One screw securing the daughterboard.
    Pergunte ao FixBot
    Comentar
  32. Motorola Edge (2022) Screen Replacement: passo 32, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 32, imagem 2 %32
    • Use your fingers or tweezers to remove the fingerprint sensor cover.
    Pergunte ao FixBot
    Comentar
  33. Motorola Edge (2022) Screen Replacement: passo 33, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 33, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
    Pergunte ao FixBot
    Comentar
  34. Motorola Edge (2022) Screen Replacement: passo 34, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 34, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 34, imagem 3 %32
    • Use the pointed end of a spudger to pry up and disconnect the black antenna's coaxial connector.
    • Pry under the rounded edge of the coaxial connector, not the straight edge. If you pry under the straight edge, you may rip the socket off the daughterboard.
    • Use the spudger to push the antenna up and away from the phone until the cable is freed from the clip securing it to the daughterboard.
    • During reassembly, make sure the cable's metal band connects to the grounding clip in the daughterboard.
    • To re-attach coaxial connectors like this one, hold the connectors in place and gently press them straight down with your finger or the pointed end of a spudger.
    Pergunte ao FixBot
    Comentar
  35. Motorola Edge (2022) Screen Replacement: passo 35, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 35, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 35, imagem 3 %32
    • Repeat the previous step for the white antenna cable.
    • During reassembly, make sure to put the cable back in its clip on the daughterboard.
    Pergunte ao FixBot
    Comentar
  36. Motorola Edge (2022) Screen Replacement: passo 36, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 36, imagem 2 %32
    • Before you perform this step, be sure you’ve ejected the SIM tray.
    • Insert the pointed end of a spudger in the gap between the daughterboard and frame near the right edge of the phone.
    • Gently pry up to release the clips securing the daughterboard.
    Pergunte ao FixBot
    Comentar
  37. Motorola Edge (2022) Screen Replacement, Remove the daughterboard: passo 37, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the daughterboard: passo 37, imagem 2 %32
    • Use your fingers or tweezers to lift the daughterboard out of its recess and remove it.
    • During reassembly, make sure all cables that connect to the daughterboard (interconnect, fingerprint sensor, and antennas) are out of they way so they don't get stuck under the daughterboard when it's reinserted.
    Pergunte ao FixBot
    Comentar
  38. Motorola Edge (2022) Screen Replacement, Pry and remove the fingerprint sensor: passo 38, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Pry and remove the fingerprint sensor: passo 38, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Pry and remove the fingerprint sensor: passo 38, imagem 3 %32
    • Use the flat side of a spudger to pry the fingerprint sensor from the frame.
    • A small amount of adhesive secures the fingerprint sensor to the frame, so this may take a few tries and some force.
    • Use your fingers or tweezers to remove the fingerprint sensor from the phone.
    • Apply new adhesive to the frame before installing the fingerprint sensor.
    Pergunte ao FixBot
    Comentar
  39. Motorola Edge (2022) Screen Replacement, Apply isopropyl alcohol: passo 39, imagem 1 %32
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the vibration motor and its contact pad to loosen the adhesive securing them.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
    Pergunte ao FixBot
    Comentar
  40. Motorola Edge (2022) Screen Replacement, Pry the vibration motor: passo 40, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Pry the vibration motor: passo 40, imagem 2 %32
    • Insert the pointed end of a spudger in the gap between the vibration motor and frame.
    • Pry up with the spudger to separate the vibration motor from the frame.
    Pergunte ao FixBot
    Comentar
  41. Motorola Edge (2022) Screen Replacement, Remove the vibration motor: passo 41, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the vibration motor: passo 41, imagem 2 %32
    • Use your fingers or tweezers to remove the vibration motor.
    • The vibration motor's flex cable is very fragile. Work slowly to prevent tearing the cable.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing a new vibration motor.
    • Apply new adhesive to your vibration motor before installing it in the frame.
    Pergunte ao FixBot
    Comentar
  42. Motorola Edge (2022) Screen Replacement, Disconnect the interconnect cable: passo 42, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the interconnect cable: passo 42, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector.
    Pergunte ao FixBot
    Comentar
  43. Motorola Edge (2022) Screen Replacement, Disconnect the screen cable: passo 43, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the screen cable: passo 43, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the screen's press connector.
    Pergunte ao FixBot
    Comentar
  44. Motorola Edge (2022) Screen Replacement, Disconnect the button assembly cable: passo 44, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the button assembly cable: passo 44, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the button assembly's press connector.
    Pergunte ao FixBot
    Comentar
  45. Motorola Edge (2022) Screen Replacement, Disconnect the white coaxial cable: passo 45, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Disconnect the white coaxial cable: passo 45, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the white antenna's coaxial connector.
    • Pry under the rounded edge of the coaxial connector, not the straight edge. If you pry under the straight edge you may rip the socket off of the motherboard.
    • During reassembly, make sure to put the cable back in its clip on the motherboard.
    Pergunte ao FixBot
    Comentar
  46. Motorola Edge (2022) Screen Replacement: passo 46, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 46, imagem 2 %32
    • Repeat the previous step on the black antenna's coaxial connector.
    Pergunte ao FixBot
    Comentar
  47. Motorola Edge (2022) Screen Replacement: passo 47, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 47, imagem 2 %32
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of tweezers to grip the bottom right corner of the motherboard near the peg on the right edge of the phone.
    • Pull the motherboard up and over the peg with a slow, steady force. This should release a few clips securing the motherboard.
    • This may require multiple attempts and significant force, as the peg wedges the motherboard in very tightly.
    Pergunte ao FixBot
    Comentar
  48. Motorola Edge (2022) Screen Replacement: passo 48, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 48, imagem 2 %32
    • Insert the pointed end of a spudger under the middle of the motherboard's bottom edge.
    • Gently pry up on the motherboard to release the clips securing it.
    Pergunte ao FixBot
    Comentar
  49. Motorola Edge (2022) Screen Replacement: passo 49, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 49, imagem 2 %32
    • Remove the motherboard from the phone.
    • Clean off the old thermal paste from the midframe and motherboard using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Ensure that all of the cables that connect to the motherboard (interconnect, battery, antenna, display, and button assembly) are out of they way so they do not get stuck under the motherboard when it's reinserted.
    Pergunte ao FixBot
    Comentar
  50. Motorola Edge (2022) Screen Replacement, Unfasten the loudspeaker: passo 50, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Unfasten the loudspeaker: passo 50, imagem 2 %32
    • Use a Phillips screwdriver to remove the 4.1 mm screw securing the loudspeaker.
    Pergunte ao FixBot
    Comentar
  51. Motorola Edge (2022) Screen Replacement, Apply isopropyl alcohol: passo 51, imagem 1 %32
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the loudspeaker's contact pad to loosen the adhesive securing it.
    Pergunte ao FixBot
    Comentar
  52. Motorola Edge (2022) Screen Replacement, Remove the loudspeaker: passo 52, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Remove the loudspeaker: passo 52, imagem 2 %32
    • Use your fingers or tweezers to remove the loudspeaker.
    • The loudspeaker's flex cable is very fragile. Work slowly to prevent tearing the cable.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing a new loudspeaker.
    Pergunte ao FixBot
    Comentar
  53. Motorola Edge (2022) Screen Replacement, Apply isopropyl alcohol: passo 53, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Apply isopropyl alcohol: passo 53, imagem 2 %32
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
    • Tilt the device as you apply alcohol to help it flow under the battery.
    • Only apply a few drops initially and apply more as necessary.
    Pergunte ao FixBot
    Comentar
  54. Motorola Edge (2022) Screen Replacement: passo 54, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 54, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 54, imagem 3 %32
    • Take care not to puncture or bend the battery during the removal process—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a suction cup to the battery.
    • Pull up on the suction cup with strong, steady force to separate the battery from the frame.
    • If the battery does not budge, apply a few more drops of isopropyl alcohol and try again.
    • Continue to pull up on the suction cup with a strong, steady force while sliding the opening pick back and forth to slice the adhesive. Continue this process until the battery separates from the midframe.
    Pergunte ao FixBot
    Comentar
  55. Motorola Edge (2022) Screen Replacement: passo 55, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 55, imagem 2 %32
    • Remove the battery from the midframe.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Follow this guide to replace the battery adhesive.
    Pergunte ao FixBot
    Comentar
  56. Motorola Edge (2022) Screen Replacement, Transfer the battery's foam strip: passo 56, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Transfer the battery's foam strip: passo 56, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Transfer the battery's foam strip: passo 56, imagem 3 %32
    • If you're reusing your old battery, skip this step.
    • Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
    • Before installing your new battery, apply the foam strip to it.
    Pergunte ao FixBot
    Comentar
  57. Motorola Edge (2022) Screen Replacement: passo 57, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 57, imagem 2 %32
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol on either side of the plastic buffer on the top left of the phone.
    Pergunte ao FixBot
    Comentar
  58. Motorola Edge (2022) Screen Replacement: passo 58, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 58, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 58, imagem 3 %32
    • Use tweezers to grip the buffer.
    • Tilt the buffer towards the bottom of the phone to disconnect it from the lip in the midframe.
    • Pull up and remove the buffer.
    Pergunte ao FixBot
    Comentar
  59. Motorola Edge (2022) Screen Replacement: passo 59, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 59, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 59, imagem 3 %32
    • Use your fingers to slowly peel the board ribbon cable from the midframe.
    • If you're having trouble separating the adhesive, use an iOpener or hair dryer to heat the cable.
    Pergunte ao FixBot
    Comentar
  60. Motorola Edge (2022) Screen Replacement, Reassembly information: passo 60, imagem 1 %32 Motorola Edge (2022) Screen Replacement, Reassembly information: passo 60, imagem 2 %32 Motorola Edge (2022) Screen Replacement, Reassembly information: passo 60, imagem 3 %32
    • This step shows how to replace the conductive adhesive for the board cable during reassembly. If your frame has this adhesive preinstalled, skip this step.
    • If necessary, cut the adhesive blocks to fit into contours of the cable channel. The adhesive doesn't need fit the contours perfectly.
    • Peel the adhesive blocks from the adhesive sheet.
    • Place the adhesives in the board cable channel. Space them evenly through the channel.
    • Peel any remaining plastic liners to expose the adhesive.
    Pergunte ao FixBot
    Comentar
  61. Motorola Edge (2022) Screen Replacement: passo 61, imagem 1 %32 Motorola Edge (2022) Screen Replacement: passo 61, imagem 2 %32 Motorola Edge (2022) Screen Replacement: passo 61, imagem 3 %32
    • Use your fingers to slowly peel the antenna cables from the right side of the midframe.
    • If you're having trouble separating the adhesive, apply a heated iOpener for 30 seconds and try again.
    • During reassembly, align the top end of the antenna cables so that they extend just out of their grooves near the motherboard.
    • There is a groove on the inner right side of the midframe for the cables. Make sure they are in the groove before reinstalling the adhesive securing them to the midframe.
    Pergunte ao FixBot
    Comentar
  62. Motorola Edge (2022) Screen Replacement: passo 62, imagem 1 %32
    • You are now left with the screen assembly.
    Pergunte ao FixBot
    Comentar
  63. Motorola Edge (2022) Screen Replacement, Earpiece speaker reassembly: passo 63, imagem 1 %32
    • If your replacement screen assembly includes an earpiece speaker, follow this step to install it.
    • Use tweezers to peel off the larger, rectangular liner.
    • Align the speaker in its proper orientation over its recess and push down to secure it.
    • Use tweezers to remove the liner on the speaker's flex cable.
    • Insert the flex cable in its groove on the frame and press down to secure it.
    Pergunte ao FixBot
    Comentar
Conclusão
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
If you bought an iFixit Fix Kit it will include extra Antenna Bracket Adhesive that's not necessary for this specific model.
4 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
195.989 Reputação
Autoria de 1.243 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.624 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 107
Ao todo: 11,413
