Ir para o conteúdo principal
Microsoft Surface Pro 2 LCD Display Replacement
Mathew B
Mathew B e 6 outros colaboradores
Última atualização em 3 de mar de 2025
10 - 20 minutos
Fácil
Melhor Introdução
Introdução
Ir para o passo 1
If your screen is unresponsive to touch, cracked, or flickering than placing your screen may solve these problems.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: passo 1, imagem 1 %32 Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: passo 1, imagem 2 %32
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 LCD Display Replacement: passo 2, imagem 1 %32
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 LCD Display Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 LCD Display Replacement: passo 4, imagem 1 %32 Microsoft Surface Pro 2 LCD Display Replacement: passo 4, imagem 2 %32 Microsoft Surface Pro 2 LCD Display Replacement: passo 4, imagem 3 %32
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
Conclusão
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Mathew B
Membro desde: 09/19/16
323 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-2, Remmell Fall 2016 Membro de USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Membros
Autoria de 11 guias
5Comentários do guia
After replacing the screen my surface will turn on but the screen is just black.... in device manager its showing up as a 'Digital Flat Panel'
yet the screen is still black.. faulty replacement panel???
austin jones - Responder
Same thing happening to me… :(
Marco - Responder
I did this procedure but i dont know why the display is not working it blink and then turnoff can somebody help me how to fix this problem
Smart Instruments - Responder
I purchased a screen replacement (LCD and Digitizer), but apparently, the flex from the motherboard to the screen (the small connector in red as well as the one on the lcd) are missing. Is there a way or place I can purchase just those flex? Or do I need to get a whole new motherboard?
Roselite - Responder
Myne doesn't boot. The display is dack nothing happens. It's like it's not charging. What do I do. Thanks
ARCHER TABULEY - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 68
Ao todo: 15,193
