Ir para o conteúdo principal
Microsoft Natural Multimedia Keyboard disassembly and cleaning
asvnix
asvnix e 4 outros colaboradores
Última atualização em November 22, 2022
Nenhuma estimativa
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
O que você precisa
Ferramentas
  1. Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 1, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 1, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 1, imagem 3 %32
    • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  2. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 2, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 2, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 2, imagem 3 %32
    • Use the flat end of a spudger to pop the keys off the keyboard.
  3. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 3, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 3, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 3, imagem 3 %32
    • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
    • Continue removing keys.
  4. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 4, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 4, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 4, imagem 3 %32
    • Remove the 10 screws from the bottom of the keyboard.
    • Remove the upper button assembly.
  5. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 5, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 5, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 5, imagem 3 %32
    • Use the tip of a spudger to push the upper button assembly buttons out from the back.
  6. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 6, imagem 1 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 6, imagem 2 %32 Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 6, imagem 3 %32
    • Remove the flexible keypad from the key caddy assembly.
    • The key caddies can be washed in the sink.
  7. Microsoft Natural Multimedia Keyboard disassembly and cleaning: passo 7, imagem 1 %32
    • The keys can also be washed.
    • Remove the metal retaining clips before washing to prevent rust.
Conclusão
10 outras pessoas executaram este guia.
asvnix
Membro desde: 11/18/12
292 Reputação
Autoria de 1 guia
3 comentários
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - Responder
I’ve had this keyboard since it was released and it just recently started having key sticking issues, so I opted to follow this guide and was pleasantly surprised at how well it worked. Thank you for this and I hope to get another 15 years out of it.
Suggestions:
1) Instead of manually cleaning, put the keys into a clear mesh bag and into the dish washer or washing machine.
2) Spray metal retainer bars with WD-40 and wipe off to help further prevent rust.
3) Let the keys and caddies sun dry for the day to ensure they do not retain any water after cleaning.
Thomas K - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 13,549
