Ir para o conteúdo principal
Michael Kors Watch Link Band Replacement
Jack Beinkampen
Jack Beinkampen e 2 outros colaboradores
Última atualização em February 26, 2025
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
Almost every watchmaker from Casio to Rolex produces watches with link bands. When adjusting or repairing a band becomes necessary, adding and removing links with a few special tools is the only solution. This comprehensive guide will demonstrate how to properly perform such manipulations on a Michael Kors brand wristwatch.
  1. Michael Kors Watch Link Band Replacement, Link Band: passo 1, imagem 1 %32
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
    I need 1 or 2 linked added to my Michael kors watch
    Jeremy Bendy - Responder
    I need 2 silver band
    pansy parsons - Responder
  2. Michael Kors Watch Link Band Replacement: passo 2, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 2, imagem 2 %32 Michael Kors Watch Link Band Replacement: passo 2, imagem 3 %32
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: passo 3, imagem 1 %32
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
    look on the inside of the band, a lot of manufacturers put a directional arrow to show you which way to remove/insert the band pin, this is because these pins have a larger end on one side, if no arrow is present then removal is bi-directional…having said this, make sure your band doesn’t use screw pins, high grades like Rolex and others use screws….
    C. Hunt - Responder
  4. Michael Kors Watch Link Band Replacement: passo 4, imagem 1 %32
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: passo 5, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 5, imagem 2 %32
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: passo 6, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 6, imagem 2 %32
    • Lastly, make sure that all the pins joining the links are secured in place.
    AAAAARRGH! I am finding it very hard to purchase one (1) rose gold and stainless-steel link to add to the MK6141 watch belonging to my wife. If anyone has any ideas, I would be very thankful. I am an 82-year-old pensioner (with reasonable computer skills) in Western Australia, but I am finding it very difficult searching on-line to locate and purchase a link. Due to age my wife's wrist has expanded slightly and as we have moved residences some of our personal effects "went missing?" (you can guess what went missing - I can't find the "missing link!) Any help would be greatly appreciated. I look forward to your responses. Cheers and a Happy New Year to all. Frank
    Frank Bartlett - Responder
Conclusão
7 outras pessoas executaram este guia.
9 comentários
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - Responder
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - Responder
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Karenclemo@gmail.com - Responder
Where can I get the white rubber link covers for strap on my mk watch
I need extra links for the MK-5249, where can I get them?
Lucky Stewart - Responder
How do you get extra links for my husband watch
Patty Warren - Responder
I need 2 links for Michael Kors watch number 5864. How do I go about getting the links?
Diana Olson - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 47
Últimos 30 dias: 201
Ao todo: 78,835
