Ir para o conteúdo principal
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
Nicolas Siemsen
Nicolas Siemsen
Última atualização em September 28, 2024
10 minutos
Muito fácil
Guia colaborativo
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: passo 1, imagem 1 %32
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 2, imagem 1 %32
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 3, imagem 1 %32
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 4, imagem 1 %32
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 5, imagem 1 %32
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 1 %32 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 2 %32 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 3 %32
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 7, imagem 1 %32
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
Conclusão
10 outras pessoas executaram este guia.
Nicolas Siemsen
Membro desde: 12/06/13
39.866 Reputação
Autoria de 79 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.677 guias
2Comentários do guia
Very informative, descriptive and point on analysis.
George T Peeke - Responder
Und wie wird dies beim Kombi gemacht?
srossius - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 56
Ao todo: 13,122
