Ir para o conteúdo principal
Mercedes W123 Brake Reservoir Rubber Seals Replacement
Nicolas Siemsen
Nicolas Siemsen e 3 outros colaboradores
Última atualização em September 27, 2024
30 minutos
Moderado
Introdução
Ir para o passo 1
The seals that cover the sensor floats for brake fluid level and the plugs between the master cylinder and the brake fluid reservoir are pretty easy to forget about when they are doing their job. But one day you'll be trying to pressure bleed or flush your brakes and you'll find brake fluid gushing out! Or, you'll find slow leaks of brake fluid when checking your oil or doing other service under the head. Nip this in the bud early on as brake fluid will ruin any paint it touches! The seals are fairly simple to replace, and this guide will help.
  1. Mercedes W123 Brake Reservoir Rubber Seals Replacement, Brake Reservoir Rubber Seals: passo 1, imagem 1 %32
    • There are a total of four rubber seals that help to keep brake fluid inside of your reservoir during use. When the rubber ages, it can crack, and harden leading to the potential for leaks.
    • The first pair of seals cover the brake fluid sensor floats. They can be easily seen on top of the reservoir. These are very visibly cracked.
    • The second set of seals, also called plugs, seal the area where the reservoir enters the master cylinder.
    • The reservoir is not under pressure when using the brakes so these seals can be in pretty rough shape and still work OK. However, if you bleed your brakes using a pressure bleeder you may find fluid shooting out! That will hint at a good time to change them...
  2. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 2, imagem 1 %32 Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 2, imagem 2 %32
    • Begin by draining the brake fluid from the system.
    • You will need to jack up the car, and remove the wheels. See the W123 guide page for help with both of these topics.
    • Now you can open the bleeder on each caliper to let the fluid drain in to an appropriate drip pan. It will take a while as it will drain slowly. Let it drain until it is barely dripping and the reservoir is empty.
  3. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 3, imagem 1 %32 Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 3, imagem 2 %32
    • Now you can proceed to remove the reservoir. Start by unplugging the two sensor wires from each of the two floats.
  4. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 4, imagem 1 %32
    • With the sensor plugs disconnected you can simply pull the reservoir out of the master cylinder. Pull straight up. It may take some force. You will have a bit of brake fluid drip and splash at this point - have a bit of water ready to rinse it off the painted surfaces underneath.
  5. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 5, imagem 1 %32 Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 5, imagem 2 %32 Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 5, imagem 3 %32
    • With the reservoir free you can pull the seals off the sensor floats. They should pull off with just some prying with your fingers.
    • See the second and third picture to get a good view of the condition of these seals once pulled. You can see for yourself why these were leaking!
  6. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 6, imagem 1 %32
    • Lightly coat the new seals with some brake cylinder grease (not brake pad grease!!) or some clean brake fluid.
    • Push the new seals on over the floats until they seat firmly in place.
  7. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 7, imagem 1 %32
    • Now it's time to replace the plugs on the master cylinder. You can get an idea here of their condition - they are pretty rough.
    • These seals should also simply pull out by hand.
  8. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 8, imagem 1 %32
    • In this picture the front plug has been removed. Proceed to carefully clean around this area with a shop towel. Do not allow dirt to enter the master cylinder - clean so that the dirt goes out, not in.
  9. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 9, imagem 1 %32
    • Coat these plugs with some brake cylinder grease, or brake fluid, and push them in. A wide flat blade screw driver used gently can help push the seals in.
    • You can see in this picture both new plugs installed.
  10. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 10, imagem 1 %32
    • Now you can push the brake reservoir in to the front plug opening. Do this with the reservoir at an angle from the master cylinder.
  11. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 11, imagem 1 %32
    • Once the front of the reservoir is inserted you can rotate the rear end in to place and push it in to the plug.
  12. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 12, imagem 1 %32 Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 12, imagem 2 %32
    • Your brake fluid reservoir is now ready to go, except for the plug connections. Re-install them.
  13. Mercedes W123 Brake Reservoir Rubber Seals Replacement: passo 13, imagem 1 %32
Conclusão
After your first drive check for leaks.
9 outras pessoas executaram este guia.
Nicolas Siemsen
Membro desde: 12/06/13
39.796 Reputação
Autoria de 79 guias
Equipe
Master Techs Membro de Master Techs
Community
326 Membros
Autoria de 1.672 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 101
Ao todo: 13,222
