Ir para o conteúdo principal
Mavic 2 Main Board  Replacement
Robert Contraction
Robert Contraction e 3 outros colaboradores
Última atualização em July 31, 2024
20 - 30 minutos
Fácil
Introdução
Ir para o passo 1
  1. Turn drone upside down to expose underside plate.
  2. Begin to remove all 8 screws from the plate . Remember the 2 middle screws are bigger than the other 6 so set those aside separately.
  3. Pull plate off, exposing the main board.
  4. Detach 3 ribbons on the top of the board. Near the head of the drone. Use spreader.
  5. Remove screw holding circuit board in. 1 near the top, 2 near the bottom.
  6. Pop of all 4 antennas at the bottom of the circuit board. Use spreader.
  7. Pull away antennas and remove board carefully.
  8. Replace new circuit board.
  9. Attach 3 ribbons.
  10. Attach 4 antennas.
  11. Screw circuit board back in.
  12. Place the plate back on and screw back in all 8 screws.
O que você precisa
  1. Mavic 2 Main Board  Replacement, Remove screws: passo 1, imagem 1 %32
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 1 %32 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 2 %32 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 3 %32
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: passo 3, imagem 1 %32 Mavic 2 Main Board  Replacement: passo 3, imagem 2 %32
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: passo 4, imagem 1 %32
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: passo 5, imagem 1 %32
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Conclusão
1Comentário do guia
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 1,527
