Ir para o conteúdo principal
Makita GA4030K Grease Replacement
Laura Ann Jagels
Laura Ann Jagels e 4 outros colaboradores
Última atualização em January 14, 2020
30 - 40 minutos
Moderada
Polícia gramatical
This guide will show you how to replace the grease in your angle grinder should it become dirty and fail to lubricate the gears.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Makita GA4030K Grease Replacement, Disk Cover: passo 1, imagem 1 %32
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Grease Replacement: passo 2, imagem 1 %32
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Grease Replacement: passo 3, imagem 1 %32 Makita GA4030K Grease Replacement: passo 3, imagem 2 %32
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Grease Replacement: passo 4, imagem 1 %32 Makita GA4030K Grease Replacement: passo 4, imagem 2 %32
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Grease Replacement, Grease: passo 5, imagem 1 %32
    • Unscrew the four 15 mm pan head screws using a Phillips #02 screwdriver.
  6. Makita GA4030K Grease Replacement: passo 6, imagem 1 %32
    • Remove the face of the device. You may need to jiggle it a little to get it off.
    • Once you see the grease, it should appear to be speckled with either dirt particles, fragments of metal, or look dark and lumpy. If you grease does not look like this, then you do not need to replace it.
  7. Makita GA4030K Grease Replacement: passo 7, imagem 1 %32
    • Use a metal spudger to scrape the old grease from the cavity.
  8. Makita GA4030K Grease Replacement: passo 8, imagem 1 %32
    • Blow compressed air into the device to make sure it is completely clean.
    • Squeeze in enough grease to fill the indents inside of the cavity.
    • Use a metal spudger to spread the grease evenly across the face of the device.
Conclusão
Laura Ann Jagels
Membro desde: 04/01/15
490 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membro de Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
Membros da 4
Autoria de 13 guias
5 comentários
Hi, what is the recommended grease?
Robert Chua - Responder
Can I use white lithium grease. Thanks my brushes appear to about half an inch long if the grease doesn’t work going to try them????
Dan Faerber - Responder
Angle grinders use a PAO lithium soap grease. Most use Nye Lubricants RheoLube 380, which is hard to source or expensive to buy.
You may substitute with Dupont Molykote G4700 grease. ereplacementParts.com has the Nye grease.
Emilio Gonzalez - Responder
Hi, I’m trying to replace the spindle of my ga4030 with the one from the ga4530, to effectively make it into a 4-1/2” model. Looking at the parts list for both of these grinders, it appears they are identical except for the spindle, disc retaining nuts, and wheel shroud/guard. Do you know if this mod is possible? It looks like I would just need to remove that small bearing that’s pressed on to the top of the spindle.
Drew - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 63
Duração total: 8,956
