Ir para o conteúdo principal
MacBook Air SSD Replacement
O que você precisa
  1. MacBook Air SSD Replacement, SSD: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
    • The two screws on the edge containing the hinge are longer than the others.
    • The eight screws in the corners and remaining edges are shorter.
  2. MacBook Air SSD Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air SSD Replacement: passo 3, imagem 1 %32 MacBook Air SSD Replacement: passo 3, imagem 2 %32
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air SSD Replacement: passo 4, imagem 1 %32
    • Remove a single T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air SSD Replacement: passo 5, imagem 1 %32 MacBook Air SSD Replacement: passo 5, imagem 2 %32
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusão
4 outras pessoas executaram este guia.
Austin Blakely
Membro desde: 03/11/19
22.209 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 64
Últimos 7 dias: 845
Últimos 30 dias: 3,898
Ao todo: 52,731
