Logitech G710+ Disassembly
O que você precisa
Remove 14 Phillips screws on the bottom of the kayboard.
Use a plastic tool to release the clips holding the case together.
Gently pry the two halves of the case apart.
Unscrew the one screw holding on the ground and pull out the cables.
A good way of getting the cables out is by putting a screwdriver right there and twisting.
Unscrew this screw
The light thing comes out with a wiggle.
The scroll wheel on the other is harder because you have to melt or brake the supports off.
Then you have to get the wheel out which comes out with a very gentle wiggle.
6 outras pessoas executaram este guia.
3 comentários
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
I broke the top left corner of the cover when I tried to open it… Good luck only breaking the clips… I didnt even apply much force at all.
guillaume_b - Responder
