Logitech Dexxa Joystick Secondary Button Cap Replacement
Introdução
Ir para o passo 1The secondary button is an important part of your controller. Your secondary button may become sticky, stuck or damaged over time. This part can be easily replaced and cleaned.
O que você precisa
Peças
Ferramentas
Exibir mais…
Remove the three 2 mm screws on the right panel.
Remove the right cover panel
Open the joystick
Unscrew the two silver 1 mm screws
Remove the circuit board
Push the purple secondary button cap out from its slot
