Lite-On iHAS324 Disc Tray Belt Replacement
O que você precisa
Ferramentas
Exibir mais…
Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
The tray should then pop open.
Pull out the tray so that it is fully extended.
Push the left tab in and slide the tray out on the left side.
Pull the gray plastic casing on the right side away from the tray.
Slide the right side of the tray out.
Ferramenta utilizada neste passo:Tweezers$4.99
Take tweezers and remove the black tray belt from the gears carefully.
3 outras pessoas executaram este guia.
