Ir para o conteúdo principal
Linear Rail V2/V3 Endstop Install
AJ Pereira
AJ Pereira e 2 outros colaboradores
Última atualização em July 26, 2024
Nenhuma estimativa
Moderado
Acidente de Marcação
Guia colaborativo
Introdução
Ir para o passo 1
CR 10 V2/V3 endstop install and adjustment.
O que você precisa
Ferramentas
  1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, imagem 1 %32 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, imagem 2 %32 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, imagem 3 %32
    • M3 Sliding T-Nut
    • Slide in the M3 T-Nut toward the middle of the printer
    • M3X12 BHCS & M3 FLAT WASHERS
    • M3x10 FHCS
    • Adjustable Endstop Mount A
    • Adjustable Endstop Mount B
    • Tighten the M3 screw into the T-Nut
  2. Linear Rail V2/V3 Endstop Install, Endstop install: passo 2, imagem 1 %32 Linear Rail V2/V3 Endstop Install, Endstop install: passo 2, imagem 2 %32
    • Adjust endstop mount until it is square with the Linear rail
    • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
  3. Linear Rail V2/V3 Endstop Install, Setting endstop position: passo 3, imagem 1 %32 Linear Rail V2/V3 Endstop Install, Setting endstop position: passo 3, imagem 2 %32
    • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
    • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
Conclusão
AJ Pereira
Membro desde: 05/29/20
2.707 Reputação
Autoria de 16 guias
Equipe
Tiny Machines 3D Membro de Tiny Machines 3D
Community
5 Membros
Autoria de 41 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 72
Ao todo: 1,335
