Ir para o conteúdo principal
Lian Li PC-011 Hard Drive Replacement
Suhaib Rahman
Suhaib Rahman e 2 outros colaboradores
Última atualização em March 9, 2023
30 minutos
Fácil
Precisa de melhores imagens
This guide is for first time builders or people that bought prebuilt computers in a Lian Li PC-011 case. This guide will walk you through how to install or replace a 3.5 hard drive in the case. It is not a very difficult task and it should only take you 30 minutes to complete.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Lian Li PC-011 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Power off the system using the button on the back of the computer.
    • Remove the power cord from the computer.
  2. Lian Li PC-011 Hard Drive Replacement: passo 2, imagem 1 %32 Lian Li PC-011 Hard Drive Replacement: passo 2, imagem 2 %32 Lian Li PC-011 Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove two thumb screws from the back of the case.
    • Slide the top panel backwards.
  3. Lian Li PC-011 Hard Drive Replacement: passo 3, imagem 1 %32 Lian Li PC-011 Hard Drive Replacement: passo 3, imagem 2 %32 Lian Li PC-011 Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the remainder of the panels by pulling upwards on them.
  4. Lian Li PC-011 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the two 3 mm Phillips #2 screws from the wire cover.
  5. Lian Li PC-011 Hard Drive Replacement: passo 5, imagem 1 %32
    • Unplug the two cables from the hard drive.
  6. Lian Li PC-011 Hard Drive Replacement: passo 6, imagem 1 %32 Lian Li PC-011 Hard Drive Replacement: passo 6, imagem 2 %32
    • Push together the bottom and top tabs and pull the hard drive tray out of the case.
  7. Lian Li PC-011 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove four #2 Phillips screws from the hard drive case in a cross pattern.
  8. Lian Li PC-011 Hard Drive Replacement: passo 8, imagem 1 %32
    • Replace the old hard drive with the new hard drive.
Conclusão
6 outras pessoas executaram este guia.
Suhaib Rahman
Membro desde: 09/19/20
446 Reputação
Autoria de 2 guias
Um comentário
Il ni à pas de languette chez moi et sa veut pas sortir
Antho - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 39
Últimos 30 dias: 121
Duração total: 7,539
