Ir para o conteúdo principal
Lenovo Y50-70 Touch Hard Disk Drive Replacement
Summer Liampetchakul
Summer Liampetchakul e 4 outros colaboradores
Última atualização em November 16, 2022
5 minutos
Moderado
Introdução
Ir para o passo 1
In this guide, the reader will go through the necessary instructions needed to replace a non-functioning hard disk drive in the Lenovo Y50-70 Touch Laptop.
This specific repair does not require any previous knowledge about computers and can be completed by a beginner using only a single Phillips #1 screwdriver and a small, plastic, prying tool.
When performing this repair, ensure you are in a static free environment so as not to provide an electrical shock to the computer and possibly further damage the device. It is also recommended to keep track of removed parts in a separate enclosed container so to not lose any necessary components needed to put the computer back together.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Lenovo Y50-70 Touch Hard Disk Drive Replacement, Hard Disk Drive: passo 1, imagem 1 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement, Hard Disk Drive: passo 1, imagem 2 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement, Hard Disk Drive: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the bottom cover.
    • Remove the bottom cover.
  2. Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 2, imagem 1 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 2, imagem 2 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 2, imagem 3 %32
    • Disconnect the battery from the motherboard.
  3. Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 3, imagem 1 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 3, imagem 2 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 3, imagem 3 %32
    • Remove the four 6 mm screws from the disk drive.
    • Lift the hard drive and pull it out to remove it.
  4. Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 4, imagem 1 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 4, imagem 2 %32 Lenovo Y50-70 Touch Hard Disk Drive Replacement: passo 4, imagem 3 %32
    • Finally, unplug the hard drive from the motherboard by pulling to disconnect the highlighted cable.
Conclusão
Equipe
IUPUI, Team 6-6, Beck Spring 2022 Membro de IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 56
Ao todo: 1,819
