Ir para o conteúdo principal
Lenovo ThinkPad T500 Speaker Replacement
nicO
nicO e 4 outros colaboradores
Última atualização em April 24, 2023
Nenhuma estimativa
Moderado
Pré-requisitos ausentes
Despedaçar
Melhor Introdução
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: passo 2, imagem 1 %32
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: passo 3, imagem 1 %32
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: passo 4, imagem 1 %32
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: passo 5, imagem 1 %32
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T500 Speaker Replacement: passo 6, imagem 2 %32
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: passo 7, imagem 1 %32
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: passo 8, imagem 1 %32
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T500 Speaker Replacement: passo 9, imagem 2 %32
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T500 Speaker Replacement: passo 10, imagem 2 %32
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad T500 Speaker Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad T500 Speaker Replacement: passo 11, imagem 3 %32
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: passo 12, imagem 1 %32
    • Remove the speakers.
Conclusão
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 702 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 1,295
