Ir para o conteúdo principal
Lenovo ThinkPad HK11e Battery Replacement
Sam Dahdal
Sam Dahdal e 2 outros colaboradores
Última atualização em April 8, 2024
3 minutos
Moderada
This tutorial will show how to replace a built-in battery on a Lenovo ThinkPad HK11e with the 14 inch screen.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: passo 2, imagem 1 %32
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: passo 4, imagem 1 %32
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: passo 5, imagem 1 %32
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: passo 7, imagem 1 %32
    • Reverse steps to mount new battery correctly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 42
Últimos 30 dias: 103
Duração total: 772
