Ir para o conteúdo principal
Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement
Michael Souza
Michael Souza e 3 outros colaboradores
Última atualização em December 30, 2024
10 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
Is your Lenovo IdeaPad Flex 5 14ARE05 overheating or crashing? A cooling fan malfunction could be what's causing it. Replacing the cooling fan is a quick and easy solution that could offer immediate results. Use this guide to remove and replace it. Before starting make sure your laptop is powered down and disconnected from any power sources.
O que você precisa
Ferramentas
Exibir mais…
  1. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 2, imagem 3 %32
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 3, imagem 1 %32
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Battery: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 5, imagem 2 %32
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Cooling Fan: passo 6, imagem 1 %32
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 7, imagem 2 %32 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: passo 7, imagem 3 %32
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
Conclusão
Michael Souza
Membro desde: 10/18/24
135 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-6, Konn Fall 2024 Membro de UMass Dartmouth, Team 1-6, Konn Fall 2024
UMASSD-KONN-F24S1G6
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 108
