Ir para o conteúdo principal
LG UD501KOJ5 Dehumidifier Sensor Replacement
Gabrielle Campbell
Gabrielle Campbell e 2 outros colaboradores
Última atualização em January 17, 2025
45 minutos
Moderada
Precisa de melhores imagens
Melhor Introdução
This guide will demonstrate how to safely replace a humidity sensor on your LG UD501KOJ5 dehumidifier.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: passo 1, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: passo 1, imagem 2 %32
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 2, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 2, imagem 2 %32
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 3, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 3, imagem 2 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 3, imagem 3 %32
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 4, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 4, imagem 2 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 4, imagem 3 %32
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 5, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 5, imagem 2 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 5, imagem 3 %32
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 6, imagem 1 %32 LG UD501KOJ5 Dehumidifier Sensor Replacement: passo 6, imagem 2 %32
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
Conclusão
Gabrielle Campbell
Membro desde: 05/12/21
133 Reputação
Autoria de 1 guia
Equipe
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Duração total: 2,386
