Ir para o conteúdo principal
LG G3 Vigor Motherboard Replacement
Jared Stickl
Jared Stickl e um outro colaborador
Última atualização em May 23, 2016
Nenhuma estimativa
Moderada
Precisa de mais images
Having technical issues with your LG G3 Vigor that are linked to your devices motherboard? You are in luck, this is the LG G3 Vigor motherboard replacement guide.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Exibir mais…
  1. LG G3 Vigor Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Motherboard Replacement: passo 2, imagem 1 %32
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Motherboard Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Motherboard Replacement: passo 5, imagem 1 %32 LG G3 Vigor Motherboard Replacement: passo 5, imagem 2 %32 LG G3 Vigor Motherboard Replacement: passo 5, imagem 3 %32
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Motherboard Replacement, Rear Facing Camera: passo 6, imagem 1 %32
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Motherboard Replacement, Front Facing Camera: passo 7, imagem 1 %32 LG G3 Vigor Motherboard Replacement, Front Facing Camera: passo 7, imagem 2 %32
    • Remove the front camera.
  8. LG G3 Vigor Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Motherboard Replacement: passo 9, imagem 1 %32 LG G3 Vigor Motherboard Replacement: passo 9, imagem 2 %32
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
Conclusão
8 outras pessoas executaram este guia.
Jared Stickl
Membro desde: 02/08/16
407 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-5, Eyestone Spring 2016 Membro de USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,019
